주요 콘텐츠로 건너뛰기
HP Pavilion G7-2289wm Optical Drive Replacement
필요한 것
  1. HP Pavilion G7-2289wm Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Optical Drive Replacement, Optical Drive: 2 단계, 이미지 1/1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Optical Drive Replacement: 3 단계, 이미지 1/2 HP Pavilion G7-2289wm Optical Drive Replacement: 3 단계, 이미지 2/2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
결론
Ryson Smith
회원 가입일: 03/19/18
636 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 UMass Dartmouth, Team S8-G1, Valliere Spring 2018 회원
UMASSD-VALLIERE-S18S8G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 10
전체 시간: 283
