주요 콘텐츠로 건너뛰기
HP Pavilion G7-2289wm RAM Replacement
필요한 것
  1. HP Pavilion G7-2289wm RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm RAM Replacement, RAM: 2 단계, 이미지 1/1
    • Loosen the screw that secures the service cover.
    • Pull the service cover towards you to remove it.
  3. HP Pavilion G7-2289wm RAM Replacement: 3 단계, 이미지 1/1
    • Unlock the tabs on each side of the ram module. (this lifts the ram module up)
  4. HP Pavilion G7-2289wm RAM Replacement: 4 단계, 이미지 1/1
    • Remove the ram module by pulling it gently away from the slot.
결론
Ryson Smith
회원 가입일: 03/19/18
636 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S8-G1, Valliere Spring 2018 UMass Dartmouth, Team S8-G1, Valliere Spring 2018 회원
UMASSD-VALLIERE-S18S8G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 126
