주요 콘텐츠로 건너뛰기
HP Pavilion N3350 Hard Drive Replacement
필요한 것
  1. HP Pavilion N3350 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over and locate the grey finger latch.
  2. HP Pavilion N3350 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the finger latch to the left to release the clip holding the battery into the laptop.
  3. HP Pavilion N3350 Hard Drive Replacement: 3 단계, 이미지 1/2 HP Pavilion N3350 Hard Drive Replacement: 3 단계, 이미지 2/2
    • While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device.
  4. HP Pavilion N3350 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • To unlock the hard drive, use a spudger to slide the button aside.
  5. HP Pavilion N3350 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Once the button is unlocked to the side, slide the hard drive enclosure away from the device.
  6. HP Pavilion N3350 Hard Drive Replacement: 6 단계, 이미지 1/1
    • The hard drive will be clipped into the underside of the hard drive enclosure and can be removed for replacement.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon Boisclair
회원 가입일: 03/19/18
530 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G8
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 183
