주요 콘텐츠로 건너뛰기
HP Pavilion N3350 Optical Drive Replacement
필요한 것
  1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Pavilion N3350 Optical Drive Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion N3350 Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. HP Pavilion N3350 Optical Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion N3350 Optical Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the green ribbon cable using a plastic opening tool.
  4. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: 4 단계, 이미지 2개 중 1개 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: 4 단계, 이미지 2개 중 2개
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
  5. HP Pavilion N3350 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion N3350 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to disconnect both cable connectors gently.
  6. HP Pavilion N3350 Optical Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion N3350 Optical Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
  7. HP Pavilion N3350 Optical Drive Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion N3350 Optical Drive Replacement: 7 단계, 이미지 2개 중 2개
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
  8. HP Pavilion N3350 Optical Drive Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion N3350 Optical Drive Replacement: 8 단계, 이미지 2개 중 2개
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lyndon Davis
회원 가입일: 03/19/18
124 평판
안내서 1개를 작성함
UMass Dartmouth, Team S3-G8, Peak Spring 2018 UMass Dartmouth, Team S3-G8, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G8
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 13
전체 시간: 360
