주요 콘텐츠로 건너뛰기
HP Pavilion Notebook 15-ab293cl Hard Drive Replacement
필요한 것
  1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Flip the laptop over so that the battery is facing upward.
  2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Slide both tab buttons inward to open the battery cover. Gently push the battery out to remove.
  3. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the black plastic hinge covers at the top corners of the laptop.
    • Use the Phillips #1 to remove the two 7.5mm screws.
    • Use the opening tool to pry the black covers off of the laptop.
  4. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Remember to remove the tabs shown in the second picture.
    • Remove all 16 - 7.5mm screws with the Phillips #1 screwdriver.
    • Pry and slide the CD/DVD drive out of the laptop case.
  5. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the two 3.5mm silver screws with the Phillips #000 and the Philips # 1.
  6. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the computer so that the screen faces you.
    • Use the pry tool to pry off the edge of the keyboard side of laptop.
  7. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • The hard drive is located in the bottom corner of the laptop.
    • Gently lift up the hard drive and pry off the white tab to release the hard drive.
  8. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Once you release the white tab from the green board, remove the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Efren Solis
회원 가입일: 09/10/18
228 평판
안내서 1개를 작성함
Gateway, Team S1-G2, Luster Fall 2018 Gateway, Team S1-G2, Luster Fall 2018 회원
GCC-LUSTER-F18S1G2
4 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 34
지난 30일: 61
전체 시간: 2,764
