주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement
필요한 것
  1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected the wire.
  5. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry up along the edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected.
  6. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 6 단계, 이미지 3개 중 3개
    • To disconnect the wire, pry up on the latch connecting it to the motherboard.
  7. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 7 단계, 이미지 3개 중 3개
    • Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop.
    • Be careful when using the metal spudger, as you could damage the internal components if the spudger is inserted too far.
    • Do not completely pull the halves apart yet because there are still wires holding them together.
  8. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
  9. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Unscrew the circuit board underneath the power button.
    • Remove this circuit board by pulling up and away on the plastic tab.
  10. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 10 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board.
    • Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate.
  11. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 11 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver.
    • Using a plastic opening tool, remove the power cable for the fan.
    • Remove the fan from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Josh Svik
회원 가입일: 04/10/18
281 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 12
전체 시간: 426
