주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 14-b013cl Screen Replacement
필요한 것
  1. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Screen Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Screen Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: 4 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: 4 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: 4 단계, 이미지 3개 중 3개
    • Using a 1.0 Flathead screwdriver, remove the two stickers covering the screws that hold the screen in place.
    • Use a Phillips #1 screwdriver to remove the two 3.2mm screws that are now visible.
  5. HP Pavilion Sleekbook 14-b013cl Screen Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 14-b013cl Screen Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 14-b013cl Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry the plastic screen protector off, sliding the tool along the seam. Press the tool in until you hear the plastic tabs clicking as they come undone.
    • Separate the plastic that makes up the hinges for the screen, as they are part of the same screen protector.
    • Use your hands or plastic tool to peel the screen protector away from the adhesive holding it in place.
  6. HP Pavilion Sleekbook 14-b013cl Screen Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the six 2.8mm screws holding the screen in place.
    • Lift the screen away from the cover until you have access to the connector cable near the bottom of the screen.
  7. HP Pavilion Sleekbook 14-b013cl Screen Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 14-b013cl Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Peel away any sticker holding the connector in place and simply pull the tab out of the connector parallel with the screen.
    • Remove the screen from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Duncan Steele
회원 가입일: 04/10/18
308 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 12
전체 시간: 527
