주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 15- b000 Fan
필요한 것
  1. HP Pavilion Sleekbook 15- b000 Fan, Battery: 1 단계, 이미지 1/1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15- b000 Fan: 2 단계, 이미지 1/1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15- b000 Fan: 3 단계, 이미지 1/2 HP Pavilion Sleekbook 15- b000 Fan: 3 단계, 이미지 2/2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15- b000 Fan: 4 단계, 이미지 1/1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15- b000 Fan, Keyboard: 5 단계, 이미지 1/1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15- b000 Fan: 6 단계, 이미지 1/1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15- b000 Fan: 7 단계, 이미지 1/1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15- b000 Fan: 8 단계, 이미지 1/1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15- b000 Fan, Case: 9 단계, 이미지 1/1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15- b000 Fan: 10 단계, 이미지 1/1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15- b000 Fan: 11 단계, 이미지 1/1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15- b000 Fan: 12 단계, 이미지 1/3 HP Pavilion Sleekbook 15- b000 Fan: 12 단계, 이미지 2/3 HP Pavilion Sleekbook 15- b000 Fan: 12 단계, 이미지 3/3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15- b000 Fan, Fan: 13 단계, 이미지 1/1
    • Remove the three x 5.5 mm restraining screws.
  14. HP Pavilion Sleekbook 15- b000 Fan: 14 단계, 이미지 1/1
    • Pull fan of of heat pipe.
  15. HP Pavilion Sleekbook 15- b000 Fan: 15 단계, 이미지 1/1
    • Remove fan.
결론
Sam Barkley
회원 가입일: 02/13/18
983 평판
안내서 8개 작성하였습니다
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 회원
USFT-CHENG-S18S11G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 367
