주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 15-b000 Case Replacement
필요한 것
  1. HP Pavilion Sleekbook 15-b000 Case Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Case Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Case Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 15-b000 Case Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Case Replacement: 4 단계, 이미지 1개 중 1개
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Case Replacement, Keyboard: 5 단계, 이미지 1개 중 1개
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Case Replacement: 6 단계, 이미지 1개 중 1개
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Case Replacement: 7 단계, 이미지 1개 중 1개
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Case Replacement: 8 단계, 이미지 1개 중 1개
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 Case Replacement, Case: 9 단계, 이미지 1개 중 1개
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 Case Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 Case Replacement: 11 단계, 이미지 1개 중 1개
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 Case Replacement: 12 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 15-b000 Case Replacement: 12 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 15-b000 Case Replacement: 12 단계, 이미지 3개 중 3개
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Shaw Bacon Graveline
회원 가입일: 02/13/18
145 평판
안내서 1개를 작성함
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 회원
USFT-CHENG-S18S11G2
4 회원들
안내서 18개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 16
전체 시간: 558
