주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 15-b142dx Battery Replacement
  1. HP Pavilion Sleekbook 15-b142dx Battery Replacement, Battery Removal: 1 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 15-b142dx Battery Replacement, Battery Removal: 1 단계, 이미지 2개 중 2개
    • Flip the laptop over and locate the release switches located at the back corners of the laptop.
  2. HP Pavilion Sleekbook 15-b142dx Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion Sleekbook 15-b142dx Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully slide the leftmost switch to the right, which is the unlock position, as shown by the orange unlock icon.
  3. HP Pavilion Sleekbook 15-b142dx Battery Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion Sleekbook 15-b142dx Battery Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion Sleekbook 15-b142dx Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the rightmost switch to the left, which will release the battery from the back of the laptop, enabling it to be pulled out.
    • Carefully pull the battery out away from the laptop, disconnecting it completely.
결론
Now that you've successfully replaced the battery, restart your laptop and resume normal operation.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jonathan
회원 가입일: 01/13/15
758 평판
안내서 3개를 작성함
USF Tampa, Team 3-3, Hickman Winter 2015 USF Tampa, Team 3-3, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G3
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 22
전체 시간: 3,169
