주요 콘텐츠로 건너뛰기
HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement
필요한 것
  1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Remove the battery from the device and unplug it.
    • Keep different sized screws separated from each other during disassembly and reassembly.
  2. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the two screws on the small back cover.
    • Remove the cover.
    • Remove the three screws that have been uncovered.
  3. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two rubber screw covers by the rubber feet of the device.
    • Using a Phillips #0 screwdriver, remove the two screws that have been uncovered.
  4. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the eight screws as directed.
    • Using a Phillips #1 screwdriver, remove the two remaining screws.
  5. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, gently pull up the keyboard starting from the bottom left corner, working your way to the bottom right corner.
    • To remove the keyboard, lift up the plastic retaining tab with the opening tool and gently pull out the ribbon wire.
  6. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the plastic cover of the laptop using the opening tool.
    • The plastic cover is fragile, be cautious during removal.
  7. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, pull up the retaining tab and and pull out the ribbon wire
    • This port is fragile, take care in removing and reinserting the ribbon wire.
  8. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove the six screws on the hard drive, then remove it.
    • Be sure to properly dispose or recycle your hard drive.
결론
작성자
3다른 기여자 명과 함께
Justin Hurley
회원 가입일: 01/14/19
1 평판
안내서 1개를 작성함
IUPUI, Team S6-G6, Wilson Spring 2019 IUPUI, Team S6-G6, Wilson Spring 2019 회원
IUPUI-WILSON-S19S6G6
3 회원들
안내서 1개 작성
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 17
전체 시간: 463
