주요 콘텐츠로 건너뛰기
HP Pavilion TouchSmart 14z-n100 Ram Replacement
필요한 것
  1. HP Pavilion TouchSmart 14z-n100 Ram Replacement, Ram: 1 단계, 이미지 1/2 HP Pavilion TouchSmart 14z-n100 Ram Replacement, Ram: 1 단계, 이미지 2/2
    • Remove the two #1 Phillips 4mm screws that hold the cover in place.
  2. HP Pavilion TouchSmart 14z-n100 Ram Replacement: 2 단계, 이미지 1/3 HP Pavilion TouchSmart 14z-n100 Ram Replacement: 2 단계, 이미지 2/3 HP Pavilion TouchSmart 14z-n100 Ram Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to remove the cover. There are several clips that hold it on.
    • Carefully slide the plastic opening tool under the edge of the cover until it comes loose.
    • You can now remove the cover.
  3. HP Pavilion TouchSmart 14z-n100 Ram Replacement: 3 단계, 이미지 1/3 HP Pavilion TouchSmart 14z-n100 Ram Replacement: 3 단계, 이미지 2/3 HP Pavilion TouchSmart 14z-n100 Ram Replacement: 3 단계, 이미지 3/3
    • There are 4 clips total, one on each side of the RAM.
    • Remove the ram by pushing the clamps outward, away from the ram
    • After the pushing the clamps outward the ram should lift up and be able to slide out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Zwissler
회원 가입일: 08/28/18
97 평판
안내서 1개 작성함
IUPUI, Team S1-G4, Arle Fall 2018 IUPUI, Team S1-G4, Arle Fall 2018 회원
IUPUI-ARLE-F18S1G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 93
