주요 콘텐츠로 건너뛰기
HP Pavilion Touchsmart 11z-e000 Fan Replacement
필요한 것
  1. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Fan: 2 단계, 이미지 1개 중 1개
    • Slide a spudger under the outer plastic cover of the laptop.
    • Pry the outer plastic cover off of the laptop, one side at a time.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew all screws attaching the fan to the metal backboard.
  4. HP Pavilion Touchsmart 11z-e000 Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the laptop over.
    • Slide a spudger in between the outer plastic cover of the keyboard and the main body of the laptop.
    • Pry the top plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force. Be careful!
  5. HP Pavilion Touchsmart 11z-e000 Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the two screws that keep the fan in place.
  6. HP Pavilion Touchsmart 11z-e000 Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the fan from the circuit board as shown
    • Carefully peel the tape connecting the fan and pull out the fan from the laptop.
결론
작성자
5다른 기여자 명과 함께
Nguyen
회원 가입일: 01/22/15
301 평판
안내서 2개를 작성함
Cal Poly, Team 21-22, Maness Winter 2015 Cal Poly, Team 21-22, Maness Winter 2015 회원
CPSU-MANESS-W15S21G22
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 1,221
