소개
If your keyboard is missing keys, sticky, or the keyboard is not responding you may need to replace your keyboard. This guide will cover how to remove the keyboard for replacement.
필요한 것
Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
Pull off the plastic cover of the laptop.
다른 3명이 해당 안내서를 완성하였습니다.
