주요 콘텐츠로 건너뛰기
HP Pavilion Wave 600-a010 hard drive Replacement
필요한 것
  1. HP Pavilion Wave 600-a010 hard drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
  2. HP Pavilion Wave 600-a010 hard drive Replacement: 2 단계, 이미지 1/1
    • Remove the three 24 mm screws from the bottom cover using a Phillips #2 screwdriver.
  3. HP Pavilion Wave 600-a010 hard drive Replacement: 3 단계, 이미지 1/1
    • Remove the bottom cover by lifting it up from chassis.
  4. HP Pavilion Wave 600-a010 hard drive Replacement: 4 단계, 이미지 1/1
    • Remove the three wires connecting the outer cover and front I/O port to the internal components (front usb and auxiliary assembly).
  5. HP Pavilion Wave 600-a010 hard drive Replacement: 5 단계, 이미지 1/2 HP Pavilion Wave 600-a010 hard drive Replacement: 5 단계, 이미지 2/2
    • Remove the outer cover by gently pulling apart and pulling away from the chassis.
  6. HP Pavilion Wave 600-a010 hard drive Replacement: 6 단계, 이미지 1/2 HP Pavilion Wave 600-a010 hard drive Replacement: 6 단계, 이미지 2/2
    • Remove rear I/O bezel using plastic opening tool to pry apart the four clips holding the I/O bezel to the chassis.
    • Remove all other remaining cables from unit using the plastic opening tool to carefully pry apart the connections.
  7. HP Pavilion Wave 600-a010 hard drive Replacement: 8 단계, 이미지 1/2 HP Pavilion Wave 600-a010 hard drive Replacement: 8 단계, 이미지 2/2
    • Remove the HDD by first using the Phillips #2 screwdriver to remove the four 23 mm screws holding together the assembly and then pulling the HDD out of the chassis.
결론
다른 5명이 해당 안내서를 완성하였습니다.
clayton stokes
회원 가입일: 09/20/17
652 평판
안내서 5개 작성하였습니다
Idaho State University, Team S4-G3, Watkins Fall 2017 Idaho State University, Team S4-G3, Watkins Fall 2017 회원
ISU-WATKINS-F17S4G3
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Why isn't there any information regarding cloning or transferring the original HDD and RECOVERY (D:) partition to the SSD. After my ssd upgrade I tried to use the recovery media and it would not work.. The portion or removal and replacing was pretty much spot on especially if you have done this type of thing before. (At least in my opinion)
CERB - 답글
Were you able to clone the HDD to your SSD? How about recovery? Also, is it possible and are there enough room for SSD and HDD? Please share your experience. Thank you!
thomastranrx - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 3,114
