주요 콘텐츠로 건너뛰기
HP Pavilion Wave 600-a014 Hard Drive Replacement
필요한 것
  1. HP Pavilion Wave 600-a014 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 Hard Drive Replacement: 2 단계, 이미지 1/2 HP Pavilion Wave 600-a014 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 Hard Drive Replacement: 3 단계, 이미지 1/2 HP Pavilion Wave 600-a014 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 Hard Drive Replacement: 4 단계, 이미지 1/2 HP Pavilion Wave 600-a014 Hard Drive Replacement: 4 단계, 이미지 2/2
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 Hard Drive Replacement: 5 단계, 이미지 1/3 HP Pavilion Wave 600-a014 Hard Drive Replacement: 5 단계, 이미지 2/3 HP Pavilion Wave 600-a014 Hard Drive Replacement: 5 단계, 이미지 3/3
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 Hard Drive Replacement: 6 단계, 이미지 1/1
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Cristian Vanegas
회원 가입일: 09/27/17
297 평판
안내서 2개 작성하였습니다
Cal Poly, Team S8-G4, Banghart Fall 2017 Cal Poly, Team S8-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G4
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Hi there, can you advise whether this was the 128gb SSD or the other 2gb drive?
Joey Franco - 답글
This model comes with a 3.5" 1TB HDD standard.
Jay Marble -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 40
전체 시간: 2,378
