주요 콘텐츠로 건너뛰기
HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement
필요한 것
  1. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: 1 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: 1 단계, 이미지 2개 중 2개
    • Turn over the computer and remove the rubber feet.
    • Remove the 8mm Philips screws indicated in red circles with a Philips #0 screwdriver.
    • Use a pry tool and lift the lid.
  2. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Pry open the casing from the back of the IO panel, as shown in the pictures.
  3. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Finally, remove the two cables circled in red from the front IO panel.
  4. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Mouse and Keyboard adapter: 4 단계, 이미지 1개 중 1개
    • Locate a blue USB adapter on the left side of the hard disk compartment.
  5. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Take off the USB with gentle but firm pressure.
    • This is a single USB adapter for both mouse and keyboard, so you must get a wireless mouse and keyboard pair, or you will have to use the extra USB for the other one.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kyaw Soe
회원 가입일: 09/27/17
324 평판
안내서 2개를 작성함
Cal Poly, Team S8-G4, Banghart Fall 2017 Cal Poly, Team S8-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G4
4 회원들
안내서 5개를 작성함
4가이드 댓글
Seems like there might be enough room for a usb 2 port hub/splitter (such as Onvian USB Splitter Cable Male to 2 Female Adapter USB) to add an additional usb dongle (such an RF or Insteon USB)? Can you confirm how much room there are?
thomastranrx - 답글
Since it's a year old project, I forgot most of the dimensions, but from my memory, it would be possible since it's located in a little groove that can probably fit a wire or two. (You can see it in step one picture)
Kyaw Soe - 답글
Can i purchase this dongle anywhere? Is there any documentation on how to pair?
will - 답글
I want to use my keyboard/mouse combo on a different computer. Can I just move the dongle from the Wave to the new computer? Why do I have to remove the red wires?
Thank you!
Laura Ann Smith - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 2,626
