주요 콘텐츠로 건너뛰기
HP Pavilion Wave 600-a014 RAM Replacement
필요한 것
  1. HP Pavilion Wave 600-a014 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Disconnect PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 RAM Replacement: 2 단계, 이미지 1/2 HP Pavilion Wave 600-a014 RAM Replacement: 2 단계, 이미지 2/2
    • Turn over computer and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 RAM Replacement: 3 단계, 이미지 1/2 HP Pavilion Wave 600-a014 RAM Replacement: 3 단계, 이미지 2/2
    • Remove the two cables connecting the motherboard to the front I/O panel.
  4. HP Pavilion Wave 600-a014 RAM Replacement: 4 단계, 이미지 1/2 HP Pavilion Wave 600-a014 RAM Replacement: 4 단계, 이미지 2/2
    • From the back I/O panel, pry open the cloth covering.
  5. HP Pavilion Wave 600-a014 RAM Replacement: 5 단계, 이미지 1/1
    • Remove the 2 black philips screws on the outside of the PC, to the left of the fan.
    • There is one on the top and one on the bottom.
  6. HP Pavilion Wave 600-a014 RAM Replacement: 6 단계, 이미지 1/3 HP Pavilion Wave 600-a014 RAM Replacement: 6 단계, 이미지 2/3 HP Pavilion Wave 600-a014 RAM Replacement: 6 단계, 이미지 3/3
    • Put your thumb on the penny-sized hole, and slide the panel upwards.
    • Remove the panel to reveal the stock blue RAM.
  7. HP Pavilion Wave 600-a014 RAM Replacement: 7 단계, 이미지 1/3 HP Pavilion Wave 600-a014 RAM Replacement: 7 단계, 이미지 2/3 HP Pavilion Wave 600-a014 RAM Replacement: 7 단계, 이미지 3/3
    • Push both of the white tabs away from the RAM stick to free the RAM.
  8. HP Pavilion Wave 600-a014 RAM Replacement: 8 단계, 이미지 1/1
    • You can now easily pull the RAM out of the socket, and replace up to two new ones!
결론
다른 2명이 해당 안내서를 완성하였습니다.
Arthur Knatt
회원 가입일: 09/27/17
149 평판
안내서 1개 작성함
Cal Poly, Team S8-G4, Banghart Fall 2017 Cal Poly, Team S8-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hello srs, i follow the link to the Amazon Ram, and it is So-DIMM, but we need UDIMM for this Wave, it is correct? Wich can we use? Thank you so much, and best regards.
Albert Garcia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 26
전체 시간: 2,947
