주요 콘텐츠로 건너뛰기
HP Pavilion Wave 600-a014 System Fan Replacement
필요한 것
  1. HP Pavilion Wave 600-a014 System Fan Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 System Fan Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 System Fan Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 System Fan Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 4 단계, 이미지 2개 중 2개
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 System Fan Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion Wave 600-a014 System Fan Replacement: 5 단계, 이미지 3개 중 3개
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 System Fan Replacement: 6 단계, 이미지 1개 중 1개
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
  7. HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: 7 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: 7 단계, 이미지 2개 중 2개
    • After removing your hard drive, remove the two 1.2mm Phillips #1 screws from the bottom of your case .
  8. HP Pavilion Wave 600-a014 System Fan Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the 8 mm Phillips #0 screw that is connected the top bezel and the top cover using the driver kit.
  9. HP Pavilion Wave 600-a014 System Fan Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Using a flathead screwdriver, remove the 8 mm Phillips #1 screw that connects the body casing and the top bezel(the one at the bottom of memory card slot).
  10. HP Pavilion Wave 600-a014 System Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the top bezel.
    • You will have to take off a pair of wire connecting the bezel with the body to be able to completely detach it.
  11. HP Pavilion Wave 600-a014 System Fan Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion Wave 600-a014 System Fan Replacement: 11 단계, 이미지 3개 중 3개
    • Turn the device to the top side where you can see the top cover and the speaker.
    • Using a flathead or Phillips #1 screwdriver, unscrew all the eight 8.0 mm screws that connect the top cover to the other components of the casing.
    • Gently remove the top cover.
  12. HP Pavilion Wave 600-a014 System Fan Replacement: 12 단계, 이미지 3개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 12 단계, 이미지 3개 중 2개 HP Pavilion Wave 600-a014 System Fan Replacement: 12 단계, 이미지 3개 중 3개
    • After removing the top cover, locate the system fan on the left side of memory compartment.
    • Remove three 1.2 cm Phillips #1 screws that connect the fan with the main body.
  13. HP Pavilion Wave 600-a014 System Fan Replacement: 13 단계, 이미지 2개 중 1개 HP Pavilion Wave 600-a014 System Fan Replacement: 13 단계, 이미지 2개 중 2개
    • Simply slide up the fan after removing the screws.
결론
작성자
1다른 기여자 명과 함께
Kyaw Soe
회원 가입일: 09/27/17
321 평판
안내서 2개를 작성함
Cal Poly, Team S8-G4, Banghart Fall 2017 Cal Poly, Team S8-G4, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G4
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,235
