주요 콘텐츠로 건너뛰기
HP Pavilion dm4-1265dx Clock Battery Replacement
필요한 것
  1. HP Pavilion dm4-1265dx Clock Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Clock Battery Replacement: 2 단계, 이미지 1/3 HP Pavilion dm4-1265dx Clock Battery Replacement: 2 단계, 이미지 2/3 HP Pavilion dm4-1265dx Clock Battery Replacement: 2 단계, 이미지 3/3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: 3 단계, 이미지 1/2 HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: 3 단계, 이미지 2/2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Clock Battery Replacement: 4 단계, 이미지 1/3 HP Pavilion dm4-1265dx Clock Battery Replacement: 4 단계, 이미지 2/3 HP Pavilion dm4-1265dx Clock Battery Replacement: 4 단계, 이미지 3/3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: 5 단계, 이미지 1/3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: 5 단계, 이미지 2/3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • The clock battery is a metallic disk near the battery port. The words "Lithium 3V" are on the face.
    • Disconnect the battery from the metallic fasteners using the tweezers.
    • Slightly bend the fasteners away from the battery.
    • Pick up the battery with the tweezers and dislodge from the fasteners.
  6. HP Pavilion dm4-1265dx Clock Battery Replacement: 6 단계, 이미지 1/1
    • Fully remove battery from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Isaiah Timbers
회원 가입일: 03/29/22
171 평판
안내서 1개 작성함
Casper College, Team 1-1, Lareau Spring 2022 Casper College, Team 1-1, Lareau Spring 2022 회원
CASC-LAREAU-S22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 24
전체 시간: 376
