주요 콘텐츠로 건너뛰기
HP Pavilion dm4-1265dx Hard Drive Replacement
필요한 것
  1. HP Pavilion dm4-1265dx Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Hard Drive Replacement: 2 단계, 이미지 1/3 HP Pavilion dm4-1265dx Hard Drive Replacement: 2 단계, 이미지 2/3 HP Pavilion dm4-1265dx Hard Drive Replacement: 2 단계, 이미지 3/3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: 3 단계, 이미지 1/2 HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: 3 단계, 이미지 2/2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Hard Drive Replacement: 4 단계, 이미지 1/3 HP Pavilion dm4-1265dx Hard Drive Replacement: 4 단계, 이미지 2/3 HP Pavilion dm4-1265dx Hard Drive Replacement: 4 단계, 이미지 3/3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3/3
    • Loosen the single captive screw holding the hard drive cover in place using a Phillips #0 screwdriver.
    • Lift the hard drive cover away and up to remove.
  6. HP Pavilion dm4-1265dx Hard Drive Replacement: 6 단계, 이미지 1/3 HP Pavilion dm4-1265dx Hard Drive Replacement: 6 단계, 이미지 2/3 HP Pavilion dm4-1265dx Hard Drive Replacement: 6 단계, 이미지 3/3
    • Lift the hard drive out of the device from the connector side.
    • Grasp the connector and pull it out of the hard drive.
    • Remove the hard drive from the laptop.
결론
Matthew Walter
회원 가입일: 03/29/22
109 평판
안내서 1개 작성함
Casper College, Team 1-1, Lareau Spring 2022 Casper College, Team 1-1, Lareau Spring 2022 회원
CASC-LAREAU-S22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 364
