주요 콘텐츠로 건너뛰기
HP Pavilion dm4-1265dx Wi-Fi Card Replacement
필요한 것
  1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 2 단계, 이미지 1/3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 2 단계, 이미지 2/3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 2 단계, 이미지 3/3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: 3 단계, 이미지 1/2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: 3 단계, 이미지 2/2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 4 단계, 이미지 1/3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 4 단계, 이미지 2/3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 4 단계, 이미지 3/3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 1/3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 2/3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using ESD safe tweezers, gently disconnect the black and white wires connecting the Wi-Fi card to the device.
    • Move the wires out of the way to allow the Wi-Fi card to spring up without obstructions.
  6. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 6 단계, 이미지 1/2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 6 단계, 이미지 2/2
    • Remove the two 3.0 mm screws from the Wi-Fi card using a Phillips #0 screwdriver.
  7. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 7 단계, 이미지 1/3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 7 단계, 이미지 2/3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: 7 단계, 이미지 3/3
    • The Wi-Fi card will spring upwards.
    • Gently remove the Wi-Fi card by pulling it away from its socket.
결론
Mason Hall
회원 가입일: 03/24/22
231 평판
안내서 2개 작성하였습니다
Casper College, Team 1-1, Lareau Spring 2022 Casper College, Team 1-1, Lareau Spring 2022 회원
CASC-LAREAU-S22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 17
전체 시간: 224
