주요 콘텐츠로 건너뛰기
HP Pavilion dm4-2015dx Keyboard Replacement
필요한 것
  1. HP Pavilion dm4-2015dx Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Turn off the device, disconnect it from all power, and remove the battery.
    • Remove the two highlighted screws to release the memory cover.
  2. HP Pavilion dm4-2015dx Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion dm4-2015dx Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two highlighted screws to release the hardware cover.
    • Remove the two screws highlighted in the 2nd image to release the hard drive cover.
  3. HP Pavilion dm4-2015dx Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the screws (as shown in pic), these two screws secure the HP keyboard.
    • Use a flathead screwdriver to release the highlighted keyboard tabs with ease.
  4. HP Pavilion dm4-2015dx Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the device right-side up and pull the keyboard frame upward along the top row of keys. There are Four (4) protruding male clips that engage along this top edge. Use a flathead screwdriver or similar tool to pry the keyboard from the frame.
    • Locate and remove the lockdown cable and unlock the keyboard cables. When prying the keyboard up, you will find resistance as a small 2 inch x 1/4 inch strip of double face tape is used to further hold the keyboard in place. (Depending upon the age of the laptop, it may require additional pulling strength to break the tapes bond.)
    • Slide out the keyboard cable and install a new HP Pavilion DM4 keyboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jacob Meloche
회원 가입일: 10/20/16
597 평판
안내서 4개를 작성함
UMass Dartmouth, Team 6-1, Martin Fall 2016 UMass Dartmouth, Team 6-1, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G1
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 2,848
