주요 콘텐츠로 건너뛰기
HP Pavilion dv1000 Hard Drive Replacement
필요한 것
  1. HP Pavilion dv1000 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Hard Drive Replacement: 3 단계, 이미지 1/2 HP Pavilion dv1000 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Hard Drive Replacement: 4 단계, 이미지 1/3 HP Pavilion dv1000 Hard Drive Replacement: 4 단계, 이미지 2/3 HP Pavilion dv1000 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • With the battery removed, locate the hard drive access panel.
  6. HP Pavilion dv1000 Hard Drive Replacement: 6 단계, 이미지 1/3 HP Pavilion dv1000 Hard Drive Replacement: 6 단계, 이미지 2/3 HP Pavilion dv1000 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Identify the two screws that attach the hard drive access panel.
    • Remove the identified screws with your #00 Philips screwdriver.
    • Lift the left edge of the access panel up and to the right to detach the hard drive access panel from the laptop.
  7. HP Pavilion dv1000 Hard Drive Replacement: 7 단계, 이미지 1/1
    • This particular laptop does not contain a hard drive-- yours will.
    • Identify the plastic tab located on the left side of the hard drive.
    • Grasp the tab, gently lift up, and slide the tab to the left to remove the hard drive from the laptop.
    • If you wish to replace your hard drive with another, the hard drive has a metal bracket screwed onto the sides of the casing. Unscrew the bracket from the old hard drive and screw it onto the new hard drive before inserting into the laptop.
결론
다른 4명이 해당 안내서를 완성하였습니다.
John Park
회원 가입일: 04/06/11
273 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-37, Forte Spring 2011 Cal Poly, Team 10-37, Forte Spring 2011 회원
CPSU-FORTE-S11S10G37
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 31
전체 시간: 12,101
