주요 콘텐츠로 건너뛰기
HP Pavilion dv1000 Keyboard Replacement
필요한 것
  1. HP Pavilion dv1000 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Keyboard Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Keyboard Replacement: 3 단계, 이미지 1/2 HP Pavilion dv1000 Keyboard Replacement: 3 단계, 이미지 2/2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Keyboard Replacement: 4 단계, 이미지 1/3 HP Pavilion dv1000 Keyboard Replacement: 4 단계, 이미지 2/3 HP Pavilion dv1000 Keyboard Replacement: 4 단계, 이미지 3/3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Keyboard Replacement, Keyboard: 5 단계, 이미지 1/1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Keyboard Replacement: 6 단계, 이미지 1/2 HP Pavilion dv1000 Keyboard Replacement: 6 단계, 이미지 2/2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler Latour
회원 가입일: 03/12/14
266 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S6G7
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 1,589
