주요 콘텐츠로 건너뛰기
HP Pavilion dv1000 RAM Replacement
필요한 것
  1. HP Pavilion dv1000 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 RAM Replacement: 2 단계, 이미지 1/1
    • Flip the laptop over.
  3. HP Pavilion dv1000 RAM Replacement: 3 단계, 이미지 1/2 HP Pavilion dv1000 RAM Replacement: 3 단계, 이미지 2/2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 RAM Replacement: 4 단계, 이미지 1/3 HP Pavilion dv1000 RAM Replacement: 4 단계, 이미지 2/3 HP Pavilion dv1000 RAM Replacement: 4 단계, 이미지 3/3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
    I bought it old but its camera & bluetooth is not working what can be done
    jagannath dey - 답글
  5. HP Pavilion dv1000 RAM Replacement, RAM: 5 단계, 이미지 1/1
    • Locate RAM access door on the bottom side of the laptop.
  6. HP Pavilion dv1000 RAM Replacement: 6 단계, 이미지 1/3 HP Pavilion dv1000 RAM Replacement: 6 단계, 이미지 2/3 HP Pavilion dv1000 RAM Replacement: 6 단계, 이미지 3/3
    • Locate the two screws holding down the RAM access cover
    • Unscrew the two screws with a size 00 Philips screwdriver.
    • Note: The screws do not detach from the cover.
  7. HP Pavilion dv1000 RAM Replacement: 7 단계, 이미지 1/2 HP Pavilion dv1000 RAM Replacement: 7 단계, 이미지 2/2
    • Lift up on the screw side of the RAM access cover to remove it.
  8. HP Pavilion dv1000 RAM Replacement: 8 단계, 이미지 1/2 HP Pavilion dv1000 RAM Replacement: 8 단계, 이미지 2/2
    • Gently pull apart the metal tabs located on both sides of the stick of RAM.
    • The RAM stick should tilt upwards.
  9. HP Pavilion dv1000 RAM Replacement: 9 단계, 이미지 1/1
    • Gently lift the the RAM up and out of its seat.
  10. HP Pavilion dv1000 RAM Replacement: 10 단계, 이미지 1/1
    • Repeat the previous two steps for the remaining stick of RAM.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Henry OBrien
회원 가입일: 04/04/11
104 평판
안내서 1개 작성함
Cal Poly, Team 10-37, Forte Spring 2011 Cal Poly, Team 10-37, Forte Spring 2011 회원
CPSU-FORTE-S11S10G37
5 회원들
안내서 9개 작성하였습니다
댓글 2개
THANKS - YOU'RE AWESOME!!!! Removing the hard drive was the fix it! the HP site never tells you this - imagine.......
marena - 답글
I had never dealt with laptop ram before and i used this guide sussusfully to remove the ram from my old HP Pavilliondv6-3055dx laptop. Thanks!
Andrew Lonero - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 25
전체 시간: 8,904
