주요 콘텐츠로 건너뛰기
HP Pavilion dv2000 Keyboard Replacement
필요한 것
  1. HP Pavilion dv2000 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 HP Pavilion dv2000 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Remove the ten 8.9mm screws (underneath where the battery would be) holding the keyboard and bezel in place.
  2. HP Pavilion dv2000 Keyboard Replacement: 2 단계, 이미지 1/2 HP Pavilion dv2000 Keyboard Replacement: 2 단계, 이미지 2/2
    • Flip the computer over to the front (keyboard-side up).
    • Gently pop the bezel off by reaching underneath it and pulling up.
    • If you are doing this for the first time, the bezel may require you to exert a little bit more force to remove it.
  3. HP Pavilion dv2000 Keyboard Replacement: 3 단계, 이미지 1/2 HP Pavilion dv2000 Keyboard Replacement: 3 단계, 이미지 2/2
    • The keyboard is held in by three small tabs near the bezel of the computer. Lifting the bezel frees the three tabs.
    • If you are removing the keyboard, the tabs will require a bit more upward force to pull away from the keyboard.
    • Remove the ribbon connecting the keyboard to the computer by pulling back on the ribbon (away from the track pad).
결론
다른 6명이 해당 안내서를 완성하였습니다.
Erik Muniz
회원 가입일: 09/09/14
820 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 2-3, Bruce Fall 2014 CSU Fullerton, Team 2-3, Bruce Fall 2014 회원
CSUF-BRUCE-F14S2G3
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
Many THANKS Erik
I am a computer imbecile. I own a hp pavilion dv2000 that is about 10-12 years old.
I may now be able to FIX it and not have to buy a whole new one
phillip james
Phillip James - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 2,754
