주요 콘텐츠로 건너뛰기
HP Pavilion dv2000 Wireless Card Replacement
필요한 것
  1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: 1 단계, 이미지 1/2 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: 1 단계, 이미지 2/2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
    • Lift up and remove the wireless card casing.
    • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
  2. HP Pavilion dv2000 Wireless Card Replacement: 2 단계, 이미지 1/2 HP Pavilion dv2000 Wireless Card Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to remove the three antennas from their sockets.
    • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
  3. HP Pavilion dv2000 Wireless Card Replacement: 3 단계, 이미지 1/3 HP Pavilion dv2000 Wireless Card Replacement: 3 단계, 이미지 2/3 HP Pavilion dv2000 Wireless Card Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Phillips #00 Screwdriver
    $5.49
    구매
    • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
    • Gently pull out your wireless card from its top side to remove it from its holding.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Erik Muniz
회원 가입일: 09/09/14
820 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 2-3, Bruce Fall 2014 CSU Fullerton, Team 2-3, Bruce Fall 2014 회원
CSUF-BRUCE-F14S2G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 17
전체 시간: 2,235
