주요 콘텐츠로 건너뛰기
HP Pavilion dv2700 Camera Module Replacement
필요한 것
  1. HP Pavilion dv2700 Camera Module Replacement, Camera Module: 1 단계, 이미지 1/1
    • Disconnect device from power source and power down.
    • Disconnect any other external devices.
  2. HP Pavilion dv2700 Camera Module Replacement: 2 단계, 이미지 1/3 HP Pavilion dv2700 Camera Module Replacement: 2 단계, 이미지 2/3 HP Pavilion dv2700 Camera Module Replacement: 2 단계, 이미지 3/3
    • Flip the laptop over so that the bottom is facing upwards.
    • Use your index finger to push the battery latch.
    • Pivot the battery upward and lift it out of the socket to remove it.
  3. HP Pavilion dv2700 Camera Module Replacement: 3 단계, 이미지 1/1
    • Flip the laptop right side up.
    • Open it as wide as the hinge allows it to.
  4. HP Pavilion dv2700 Camera Module Replacement: 4 단계, 이미지 1/3 HP Pavilion dv2700 Camera Module Replacement: 4 단계, 이미지 2/3 HP Pavilion dv2700 Camera Module Replacement: 4 단계, 이미지 3/3
    • Use an opening tool to remove the four rubber screw covers located across the top of the bezel.
    • Remove the Phillips PM2.5×5.0 screws.
    • Remove the two rubber screw covers located at the bottom left and right of the bezel.
  5. HP Pavilion dv2700 Camera Module Replacement: 5 단계, 이미지 1/3 HP Pavilion dv2700 Camera Module Replacement: 5 단계, 이미지 2/3 HP Pavilion dv2700 Camera Module Replacement: 5 단계, 이미지 3/3
    • Flex the inside edges of the left and right sides and the top edge of the display bezel.
    • Lift the bezel with your finger until it disengages from the display enclosure.
  6. HP Pavilion dv2700 Camera Module Replacement: 6 단계, 이미지 1/3 HP Pavilion dv2700 Camera Module Replacement: 6 단계, 이미지 2/3 HP Pavilion dv2700 Camera Module Replacement: 6 단계, 이미지 3/3
    • Remove the two Phillips PM2.5×4.0 screws that secure camera module.
    • Release the camera module assembly unit by simply pulling it out of the laptop.
  7. HP Pavilion dv2700 Camera Module Replacement: 7 단계, 이미지 1/3 HP Pavilion dv2700 Camera Module Replacement: 7 단계, 이미지 2/3 HP Pavilion dv2700 Camera Module Replacement: 7 단계, 이미지 3/3
    • Disconnect the camera module cable from the camera module itself by pulling it out.
    • Be careful not to break the camera module cable.
    • Turn the module upside down and remove the screws for the camera bracket.
    • Remove the camera module from the bracket.
결론
Kayaen Jardine
회원 가입일: 07/05/20
145 평판
안내서 1개 작성함
York University, Team S1-G35, Allen Summer 2020 York University, Team S1-G35, Allen Summer 2020 회원
YORK-ALLEN-SU20S1G35
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 476
