주요 콘텐츠로 건너뛰기
HP Pavilion dv2700 Hard Drive Replacement
필요한 것
  1. HP Pavilion dv2700 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • To remove the battery, pull the tab to the left and lift the battery from the computer.
  2. HP Pavilion dv2700 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Using a #0 Phillips Head screwdriver, unscrew the hard drive cover.
    • The screws cannot be removed from the cover.
    • To remove the cover, lift up and to the left.
  3. HP Pavilion dv2700 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Using a #0 Phillips Head screwdriver, remove the screws holding the hard drive in place.
    • These are the two screws located on the right side of the hard drive.
  4. HP Pavilion dv2700 Hard Drive Replacement: 4 단계, 이미지 1/2 HP Pavilion dv2700 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Lift the tab connected to the hard drive in order to remove it.
    • The hard drive may be difficult to remove by grabbing the tab. In this case, use the spudger to gently pry it from the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jared Opperman
회원 가입일: 09/24/15
161 평판
안내서 1개 작성함
Texas Tech, Team 22-6, Rauch Fall 2015 Texas Tech, Team 22-6, Rauch Fall 2015 회원
TTU-RAUCH-F15S22G6
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
Hi, I have a seagate hard drive that was mounted on a hp pavillon dv series computer. I only have the hard disk and I can not find any serial adapter that can be connected to the hard disk connector. I saw on amazon and ebay but I did not find anything. Can you help me? Thank you!
L. S. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 3,014
