주요 콘텐츠로 건너뛰기
HP Pavilion dv2913cl Keyboard Replacement
필요한 것
  1. HP Pavilion dv2913cl Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Locate battery on the bottom of the laptop.
  2. HP Pavilion dv2913cl Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide the battery release bar to the left, this should release the battery so you can then remove it.
  3. HP Pavilion dv2913cl Keyboard Replacement: 3 단계, 이미지 1/2 HP Pavilion dv2913cl Keyboard Replacement: 3 단계, 이미지 2/2
    • Locate the three screws for the keyboard by finding the small keyboard picture, remove these screws and flip the laptop back over.
  4. HP Pavilion dv2913cl Keyboard Replacement: 4 단계, 이미지 1/1
    • Open the laptop so the keyboard is facing upwards and towards you.
  5. HP Pavilion dv2913cl Keyboard Replacement: 5 단계, 이미지 1/2 HP Pavilion dv2913cl Keyboard Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to get underneath the plastic bar above the keyboard, pry upwards. Pry the keyboard upwards gently.
    • Be careful not to pull the keyboard too hard so you do not rip the silver ribbon cable attached to the laptop.
  6. HP Pavilion dv2913cl Keyboard Replacement: 6 단계, 이미지 1/2 HP Pavilion dv2913cl Keyboard Replacement: 6 단계, 이미지 2/2
    • Release the ribbon cable by using a flathead screw driver. Release the two tabs holding the cable and pull outwards.
    • Pull the keyboard up and out from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Braga
회원 가입일: 10/24/16
230 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 UMass Dartmouth, Team 2-7, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 161
