주요 콘텐츠로 건너뛰기
HP Pavilion dv2913cl RAM Replacement
필요한 것
  1. HP Pavilion dv2913cl RAM  Replacement, Ram: 1 단계, 이미지 1/2 HP Pavilion dv2913cl RAM  Replacement, Ram: 1 단계, 이미지 2/2
    • Unscrew the two screws on the center panel of the device .
    • Then gently remove the center panel.
  2. HP Pavilion dv2913cl RAM  Replacement: 2 단계, 이미지 1/3 HP Pavilion dv2913cl RAM  Replacement: 2 단계, 이미지 2/3 HP Pavilion dv2913cl RAM  Replacement: 2 단계, 이미지 3/3
    • Gently push the silver clamps on both sides of the RAM stick on top.
    • Pushing the clamps back could damage the device. push far enough to remove the RAM card.
    • Now remove the RAM stick on top from the device.
  3. HP Pavilion dv2913cl RAM  Replacement: 3 단계, 이미지 1/3 HP Pavilion dv2913cl RAM  Replacement: 3 단계, 이미지 2/3 HP Pavilion dv2913cl RAM  Replacement: 3 단계, 이미지 3/3
    • Gently push the silver clamps on both sides of the bottom RAM stick.
    • Pushing the clamps back could damage the device. Push gently just far enough to remove the RAM stick.
    • Now remove the bottom RAM stick from the device.
  4. HP Pavilion dv2913cl RAM  Replacement: 4 단계, 이미지 1/1
    • this is the device with both RAM sticks removed.
결론
Jeremy Jackson
회원 가입일: 10/27/16
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 UMass Dartmouth, Team 2-7, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 104
