주요 콘텐츠로 건너뛰기
HP Pavilion dv2913cl WiFi receiver Replacement
필요한 것
  1. HP Pavilion dv2913cl WiFi receiver Replacement, WiFi receiver: 1 단계, 이미지 1/1
    • Begin by locating the smallest panel with one screw attaching it to the laptop computer.
  2. HP Pavilion dv2913cl WiFi receiver Replacement: 2 단계, 이미지 1/1
    • Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
  3. HP Pavilion dv2913cl WiFi receiver Replacement: 3 단계, 이미지 1/1
    • Remove the two screws that hold down the receiver.
    • Gently slide the chip out of the socket.
  4. HP Pavilion dv2913cl WiFi receiver Replacement: 4 단계, 이미지 1/2 HP Pavilion dv2913cl WiFi receiver Replacement: 4 단계, 이미지 2/2
    • Remove the two wires labelled AUX and MAIN from the chip.
    • Remember where these were attached previously as it is important for proper functionality after the replacement.
결론
Adam Braga
회원 가입일: 10/24/16
230 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 UMass Dartmouth, Team 2-7, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 10
전체 시간: 125
