주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion dv4000 Hard Drive Replacement
필요한 것
  1. HP Pavilion dv4000 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion dv4000 Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
결론
To replace the hard drive, follow these instructions in reverse.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chris Marshall
회원 가입일: 10/18/16
481 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 21
전체 시간: 2,111
