주요 콘텐츠로 건너뛰기
HP Pavilion dv4000 Hard Drive Replacement
필요한 것
  1. HP Pavilion dv4000 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion dv4000 Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
결론
To replace the hard drive, follow these instructions in reverse.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chris Marshall
회원 가입일: 10/18/16
454 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 1,925
