주요 콘텐츠로 건너뛰기
HP Pavilion dv4000 Keyboard Replacement
필요한 것
  1. HP Pavilion dv4000 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Keyboard Replacement, Keyboard: 4 단계, 이미지 1개 중 1개
    • Have your device open in front of you for easy access to the keyboard.
  5. HP Pavilion dv4000 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
    • Be careful not to damage any components with the tool while prying.
  6. HP Pavilion dv4000 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the plastic piece up.
    • When lifting this piece, be careful not to damage the ribbon strip connected to it.
  7. HP Pavilion dv4000 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion dv4000 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion dv4000 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
    • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
    • Remove plastic piece and set aside.
  8. HP Pavilion dv4000 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Locate the four 2x2 mm screws that hold the keyboard in place.
  9. HP Pavilion dv4000 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
  10. HP Pavilion dv4000 Keyboard Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion dv4000 Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    • Lift the keyboard up.
    • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
  11. HP Pavilion dv4000 Keyboard Replacement: 11 단계, 이미지 1개 중 1개
    • Locate where the ribbon strip is connected to the motherboard.
  12. HP Pavilion dv4000 Keyboard Replacement: 12 단계, 이미지 2개 중 1개 HP Pavilion dv4000 Keyboard Replacement: 12 단계, 이미지 2개 중 2개
    • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
    • Be careful during this step as these clips are very easy to break.
  13. HP Pavilion dv4000 Keyboard Replacement: 13 단계, 이미지 3개 중 1개 HP Pavilion dv4000 Keyboard Replacement: 13 단계, 이미지 3개 중 2개 HP Pavilion dv4000 Keyboard Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nick LaMarche
회원 가입일: 10/18/16
373 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-2, Catania Fall 2016 UMass Dartmouth, Team 4-2, Catania Fall 2016 회원
UMASSD-CATANIA-F16S4G2
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 992
