소개
These instructions detail how to take apart an HP dv5000 laptop computer, how to identify and remove the fan from the computer, and how to reassemble the computer.
필요한 것
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 5mm Phillips screws on the right side of the RAM cover.
Lift the right side of the RAM cover, and remove it.
Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
The white wire connects to the AUX terminal.
The black wire connects to the MAIN terminal.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
Remove the two 11.0mm screws at the corners on either side of the battery compartment.
Remove the three 6.0mm screws.
Remove the two 5.0mm screws.
Remove the 6.0mm screw in the middle of the battery compartment.
Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
When reassembling, you need to push the little tabs next to the connector up before connecting the cable.
Flip the computer over to access the screws on the underside of the frame.
Remove the two 3.0mm screws.
Remove the 5.0mm screw.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 2개
Kindly add this on dv 4000 also
