이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The hard drive is the memory storage device located on the bottom of the laptop, directly below the track pad.
필요한 것
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
To reinstall the hard drive and reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
