주요 콘텐츠로 건너뛰기
HP Pavilion dv5000 Keyboard Replacement
필요한 것
  1. HP Pavilion dv5000 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Keyboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  3. HP Pavilion dv5000 Keyboard Replacement: 3 단계, 이미지 1/1
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  4. HP Pavilion dv5000 Keyboard Replacement: 4 단계, 이미지 1/1
    • Be careful not to bend the keyboard switch cover too far when removing it.
  5. HP Pavilion dv5000 Keyboard Replacement: 5 단계, 이미지 1/1
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  6. HP Pavilion dv5000 Keyboard Replacement: 6 단계, 이미지 1/2 HP Pavilion dv5000 Keyboard Replacement: 6 단계, 이미지 2/2
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
    When reassembling, you need to push the little tabs next to the connector up before connecting the cable.
    Dimitri Cooper - 답글
  7. HP Pavilion dv5000 Keyboard Replacement: 7 단계, 이미지 1/1
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  8. HP Pavilion dv5000 Keyboard Replacement: 8 단계, 이미지 1/1
    • Lift the keyboard off the keyboard frame.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Alex Kwok
회원 가입일: 10/05/10
274 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 회원
CPSU-REGAN-F10S21G34
4 회원들
안내서 11개 작성하였습니다
댓글 2개
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Arkadiusz Gąsior - 답글
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
stevefranklin75 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 11,231
