주요 콘텐츠로 건너뛰기
소개
The battery of the HP Pavilion is made to last for only a period of time, after which the battery tends to run low sooner than usual. This means the battery capacity has lessened and may need a replacement. This guide will walk you through the process of accessing the RTC Battery of an HP Pavilion dv5000 in order to replace it.
부품
지정된 부품이 없습니다.
  1. Turn off the computer, and unplug it from all external power sources.
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. Remove the two 5mm Phillips screws on the right side of the RAM cover. Lift the right side of the RAM cover, and remove it. Lift the right side of the RAM cover, and remove it.
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card. The white wire connects to the AUX terminal.
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  4. Remove the two 6.0mm Phillips screws from the wifi card. Remove the wifi card.
    • Remove the two 6.0mm Phillips screws from the wifi card.
    • Remove the wifi card.
  5. Remove the RTC Battery from the battery holder. Remove the RTC Battery from the battery holder. Remove the RTC Battery from the battery holder.
    • Remove the RTC Battery from the battery holder.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Farid Khoshnevissan
회원 가입일: 2010년 10월 11일
772 평판
안내서 4개 작성하였습니다
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 회원
CPSU-REGAN-F10S21G34
4 회원들
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 16
전체 시간: 10,973
