필요한 것
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 11.0mm screws at the corners on either side of the battery compartment. (shown by the red circles)
Remove the three 6.0mm screws. (shown by the blue circles)
Remove the two silver 5.0mm screws. (shown by the yellow circles)
Remove the 6.0mm screw in the middle of the battery compartment. (shown by the teal circle)
다른 한 분이 해당 안내서를 완성하였습니다.
