주요 콘텐츠로 건너뛰기
HP Pavilion dv5000 Wifi Card
필요한 것
  1. HP Pavilion dv5000 Wifi Card, Battery: 1 단계, 이미지 1/1
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 Wifi Card, RAM Cover: 2 단계, 이미지 1/3 HP Pavilion dv5000 Wifi Card, RAM Cover: 2 단계, 이미지 2/3 HP Pavilion dv5000 Wifi Card, RAM Cover: 2 단계, 이미지 3/3
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 Wifi Card, Wifi Card: 3 단계, 이미지 1/2 HP Pavilion dv5000 Wifi Card, Wifi Card: 3 단계, 이미지 2/2
    • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
    • The white wire connects to the AUX terminal.
    • The black wire connects to the MAIN terminal.
  4. HP Pavilion dv5000 Wifi Card: 4 단계, 이미지 1/2 HP Pavilion dv5000 Wifi Card: 4 단계, 이미지 2/2
    • Remove the two 6.0mm Phillips screws from the wifi card.
    • Remove the wifi card.
결론
Sam Kaplan
회원 가입일: 10/11/10
256 평판
안내서 2개 작성하였습니다
Cal Poly, Team 21-34, Regan Fall 2010 Cal Poly, Team 21-34, Regan Fall 2010 회원
CPSU-REGAN-F10S21G34
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 17
전체 시간: 7,115
