주요 콘텐츠로 건너뛰기
HP Pavilion dv6-1245dx RAM Replacement
필요한 것
  1. HP Pavilion dv6-1245dx RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Shut down the computer and unplug it from the outlet.
    • All screws removed in this guide will require a Phillips #00 screwdriver.
  2. HP Pavilion dv6-1245dx RAM Replacement: 2 단계, 이미지 1/1
    • Turn the computer upside down.
  3. HP Pavilion dv6-1245dx RAM Replacement: 3 단계, 이미지 1/1
    • Loosen the three screws from the memory module compartment cover
    • Screws will not come all the way out.
  4. HP Pavilion dv6-1245dx RAM Replacement: 4 단계, 이미지 1/1
    • Remove the memory module compartment cover.
  5. HP Pavilion dv6-1245dx RAM Replacement: 5 단계, 이미지 1/3 HP Pavilion dv6-1245dx RAM Replacement: 5 단계, 이미지 2/3 HP Pavilion dv6-1245dx RAM Replacement: 5 단계, 이미지 3/3
    • Remove the first memory module by spreading apart the two silver retaining tabs, using your thumb and index finger.
    • Pull and lift the green memory module upward at a 45-degree angle, and then pull the memory module out of the computer.
    • If you are replacing both memory cards, repeat this step with the bottom memory card.
  6. HP Pavilion dv6-1245dx RAM Replacement: 6 단계, 이미지 1/1
    • To replace the memory card, insert the card at a 45-degree angle, then push into slot.
    • Push down gently so the silver retaining tabs click back into place.
    • If you are replacing both memory cards, replace the bottom card (closest to the system board) first.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jaime
회원 가입일: 01/23/14
562 평판
안내서 1개 작성함
New Mexico State, Team 1-3, Sheppard Spring 2014 New Mexico State, Team 1-3, Sheppard Spring 2014 회원
NMSU-SHEPPARD-S14S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 18
전체 시간: 2,375
