주요 콘텐츠로 건너뛰기
HP Pavilion dv6-2155dx Hard Drive Replacement
필요한 것
  1. HP Pavilion dv6-2155dx Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 HP Pavilion dv6-2155dx Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Shutdown your computer and remove the battery before beginning the replacement.
    • Loosen the screws using Phillips #01 screwdriver with the extension attached.
    • The screws will not come out completely but stay on the panel.
  2. HP Pavilion dv6-2155dx Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • After removing the two screws securing the Hard Drive to the bottom case, remove the panel to reveal the hard drive.
  3. HP Pavilion dv6-2155dx Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion dv6-2155dx Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Locate the tab of the black Mylar film on the right hand side of the hard drive.
    • Gently grip it with your thumb and index finger.
  4. HP Pavilion dv6-2155dx Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion dv6-2155dx Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the Hard Drive to the right to loosen the it from the frame.
    • The left side of the hard drive will pop up and should slide out freely until you see the black connector on it's right side, connecting it to the computer.
  5. HP Pavilion dv6-2155dx Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv6-2155dx Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • When removing the Hard Drive from the frame, you will see a black connector on it's right side.
    • Turn the Hard Drive over and grasp the Hard Drive with one hand as you grip the connector with the other hand to remove the connector from the hard drive.
    • To safely remove the Hard Driver, do not wiggle or jerk the connector off of the Hard Drive, pull straight off.
결론
작성자
4다른 기여자 명과 함께
Lisa Redder
회원 가입일: 10/18/16
318 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 UMass Dartmouth, Team 2-2, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G2
3 회원들
안내서 5개를 작성함
1가이드 댓글
Can I transfer the information on the hard drive to another computer? How? My laptop won’t turn on and I’ve tried everything.
Sheree Norton - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 42
전체 시간: 2,180
