주요 콘텐츠로 건너뛰기
HP Pavilion dv6-2158nr Hard Drive Replacement
필요한 것
  1. HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 HP Pavilion dv6-2158nr Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/3 HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: 2 단계, 이미지 2/3 HP Pavilion dv6-2158nr Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer.
    • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
  3. HP Pavilion dv6-2158nr Hard Drive Replacement: 3 단계, 이미지 1/2 HP Pavilion dv6-2158nr Hard Drive Replacement: 3 단계, 이미지 2/2
    • Use the Mylar tab to lift the hard drive up, and then slide out to release it from the hard drive bay.
  4. HP Pavilion dv6-2158nr Hard Drive Replacement: 4 단계, 이미지 1/3 HP Pavilion dv6-2158nr Hard Drive Replacement: 4 단계, 이미지 2/3 HP Pavilion dv6-2158nr Hard Drive Replacement: 4 단계, 이미지 3/3
    • Disconnect the hard drive cable from the system board.
    • Remove four 4mm screws from the hard drive case.
    • There are two screws on each side of the hard drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Chad
회원 가입일: 01/13/14
1,123 평판
안내서 6개 작성하였습니다
Cal Poly, Team 10-34, Maness Winter 2014 Cal Poly, Team 10-34, Maness Winter 2014 회원
CPSU-MANESS-W14S10G34
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 16
전체 시간: 3,034
