이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This repair guide will show you how to remove the keyboard in case you need to replace it.
Before proceeding with this repair guide, make sure to have a large area to place the removed components and to keep screws organized.
Before removing the keyboard, follow these steps:
Shut down the computer
If unsure whether your computer is off or in hibernation, turn it on, and then shut down through the operating system.
Disconnect devices and power
Disconnect all external devices, plug-ins and power from the computer.
필요한 것
Locate the battery on the bottom side of the laptop.
Slide the release switch and the battery will pop out.
Remove the battery
Using a Philips #1 Loosen the three 7mm captive screws that secure the memory module compartment cover to the computer.
Lift the rear edge of the cover, swing it up and to the front, and remove the cover.
With laptop upside down locate the three sets of screws that fasten the keyboard and switch cover.
Two Phillips 7mm screws that secure the switch cover to the computer.
Four Phillips 4.0mm screws that secure the switch cover to the computer. (these are inside the battery bay)
Four Philips 7mm screws that secure the keyboard to the computer.
Remove all ten screws.
다른 6명이 해당 안내서를 완성하였습니다.
