주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The random access memory (RAM) stores temporary data for programs to use while they are running. Some programs use a lot of memory so it may be useful to replace RAM with ones with more memory on them.
부품
지정된 부품이 없습니다.
  1. Locate the battery on the bottom side of the laptop. Slide the release switch and the battery will pop out. Remove the battery
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
    • Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
  3. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  4. Remove cover and expose the memory module by lifting the cover up like its on a hinge. Remove cover and expose the memory module by lifting the cover up like its on a hinge. Remove cover and expose the memory module by lifting the cover up like its on a hinge.
    • Remove cover and expose the memory module by lifting the cover up like its on a hinge.
  5. Locate the release tabs on both sides of the RAM. Use non-conductive pointing tool or fingers to prevent static build up and damaging components. Pull the metal tabs away from the memory to release it.
    • Locate the release tabs on both sides of the RAM.
    • Use non-conductive pointing tool or fingers to prevent static build up and damaging components.
    • Pull the metal tabs away from the memory to release it.
    • Pull RAM away from clips to remove from device
    • Repeat for second RAM if necessary
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chad
회원 가입일: 2014년 01월 13일
1,033 평판
안내서 6개 작성하였습니다
Cal Poly, Team 10-34, Maness Winter 2014 Cal Poly, Team 10-34, Maness Winter 2014 회원
CPSU-MANESS-W14S10G34
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,379
