주요 콘텐츠로 건너뛰기
HP Pavilion dv6-6117dx Hard Drive Replacement
필요한 것
  1. HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion dv6-6117dx Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion dv6-6117dx Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screw driver, remove the four 4mm screws holding the hard drive in place.
  5. HP Pavilion dv6-6117dx Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion dv6-6117dx Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Using a plastic spudger, lift up the hard drive from the top left corner and flip it to the right of the laptop like opening a book.
    • There is a cable connecting the hard drive to the laptop, be sure not to pull it out when flipping the hard drive.
  6. HP Pavilion dv6-6117dx Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the tab at the end of the cable connecting the hard drive to the laptop.
  7. HP Pavilion dv6-6117dx Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion dv6-6117dx Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screw driver, remove the four 4mm screws on each side of the hard drive attaching it to its carriage.
  8. HP Pavilion dv6-6117dx Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the hard drive from its carriage.
  9. HP Pavilion dv6-6117dx Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 HP Pavilion dv6-6117dx Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the SATA cable from the hard drive.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joshua Holme
회원 가입일: 03/19/18
765 평판
안내서 4개를 작성함
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 UMass Dartmouth, Team S6-G3, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G3
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 48
전체 시간: 3,362
