주요 콘텐츠로 건너뛰기
HP Pavilion dv6-6117dx RAM Replacement
필요한 것
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: 1 단계, 이미지 1/2 HP Pavilion dv6-6117dx RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: 2 단계, 이미지 1/2 HP Pavilion dv6-6117dx RAM Replacement: 2 단계, 이미지 2/2
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: 3 단계, 이미지 1/3 HP Pavilion dv6-6117dx RAM Replacement: 3 단계, 이미지 2/3 HP Pavilion dv6-6117dx RAM Replacement: 3 단계, 이미지 3/3
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: 4 단계, 이미지 1/2 HP Pavilion dv6-6117dx RAM Replacement: 4 단계, 이미지 2/2
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: 5 단계, 이미지 1/2 HP Pavilion dv6-6117dx RAM Replacement: 5 단계, 이미지 2/2
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
결론
Joshua Holme
회원 가입일: 03/19/18
765 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S6-G3, Bernier Spring 2018 UMass Dartmouth, Team S6-G3, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 22
전체 시간: 737
