소개
Are you unable to connect to WiFi? Your WiFi adapter may be broken. This guide will walk you through replacing it with a new, working WiFi adapter, with only a spudger and a Phillips #0 screw driver. Once you have a clean work space and the tools required, follow the steps below.
필요한 것
Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
다른 2명이 해당 안내서를 완성하였습니다.
